Orange Light on hub 3
JayneC1
Hi there
A constant orange light has appeared on my hub 3, this toes in with really poor internet, dropping in and out over the past few weeks. My ring alarm recorded it dropping out over 20 times last night. Tried a full reset and orange light still there. Can never get through to Virgin. I work from home so would love this sorting out.
1 ACCEPTED SOLUTION
Accepted Solutions
Roger_Gooner
It's best to call VM at opening time, i.e. 8am.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
8 REPLIES 8
That is normal in an ageing Hub3 - the 1p LED fails/fades over time - it indicates nothing re its performance.
Are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Hi there. Tried with Ethernet and it’s not working when it drops out so I think hub? I just want them to send me a new one but can’t seem to get anyone to sort it.
Roger_Gooner
Hi @JayneC1
Welcome to the community forums
Sorry to hear that you're having service issues this Monday.
I have checked the systems at my side and there is no area outages or issues with your hub specifications that I can see.
Are you still experiencing the same service concerns today, or have they since cleared up?
Here to help 🙂
Virgin Media Forums Agent
Carley
Hi there. It happens every few days, started a few months back. Nothing has changed, router in same place but just keeps dropping out. It’s causing problems with our house alarm and me working from home. My phone keeps losing connection and yet if I go to my mothers is fine so I believe it’s the router.
Do this - especially set up the BQM
________
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Hi, I am having the same issue with my hub - a constant orange light despite factory resetting my hub 3 times. The signal of strength drops off significantly, leaving WIFI blackspots in multiple rooms, despite it being a small terraced house.
I have been having these issues since August 2022 with no imporement and still the same orange light on my hub
Thanks for your post on our Community Forums. and very warm welcome to you @georgemil651!
Sorry to hear of the orange light on your hub.
Does this feel too hot to touch?
Can you please confirm if you've been able to run any Broadband Quality Monitor on the connection to see when the disconnections are happening?
David_Bn
