kevkdg
  • 59
Dialled in
Message 1 of 14
Optimal Settings for Asus ZenWiFi AX6600 XT8 with Hub 4 in Router Mode (Gig 1 Package)
This is a question for anyone running an Asus ZenWiFi XT8 with their hub in router mode.
Do you recall what XT8 settings you changed from the defaults in order for compatibility with your VM Hub in router mode and/or changes you made to improve range/performance/experience etc of the XT8's.
I have a pair of these devices ready to set up and run as a mesh network with my Hub 4 in router mode on the Gig1 package.
I am confident in putting my Hub 4 into modem mode.  This is more around XT8 settings people may have changed from experience.
Many thanks.
gary_dexter
  • 32.63K
  • 2.02K
  • 4.48K
Message 2 of 14
Re: Optimal Settings for Asus ZenWiFi AX6600 XT8 with Hub 4 in Router Mode (Gig 1 Package)
You need to put the hub into Modem Mode
Andrew-G
  • 11.14K
  • 1.73K
  • 5.32K
Message 3 of 14
I can't speak from experience of the XT8, but as a general rule most mesh systems are best left to themselves and their default settings.  I'd set it up, see how things are and only then consider playing with settings if there's something that looks to need improving.
Stobbsy74
  • 172
  • 5
  • 45
Superfast
Message 4 of 14
If you want to run the VM hub in router mode, I disabled the hub wifi and put the xt8  into access point operation mode. Everything else i kept same as default apart from ssid names and passwords, which I put to same as my vm hub.
Stobbsy74
  • 172
  • 5
  • 45
Superfast
Message 5 of 14
When running hub in modem mode, my xt8 just runs with default settings apart from prementioned ssid and passwords.
For both setups I swapped backhaul mode to wired as opposed to wireless as I'm using ethernet cable between them.
gary_dexter
  • 32.63K
  • 2.02K
  • 4.48K
Message 6 of 14
There are some professional wifi settings to change if you want optimise things a bit
Andrew-G
  • 11.14K
  • 1.73K
  • 5.32K
Message 7 of 14
If you buy a premium piece of kit like an Asus XT8, and put it in access point mode, then (even with the same SSID) you've got competing wifi signals that don't work as a mesh, and you're disabling the top quality XT8 mesh-purposed router in order to rely on the hub's wheezing pound shop router, as well as exposing yourself to VM's flakey router software and occasional unasked for settings changes.
I'm really struggling to see any benefits from that - seems like buying a Ferrari and then removing the tyres to fit a set of unbranded, part-used remoulds "because they've still got some tread on them, and it seems a waste not to use them".
kevkdg
  • 59
Dialled in
Message 8 of 14
Hi Gary,
Care to expand on these parameters and optimal settings?
Many Thanks
gary_dexter
  • 32.63K
  • 2.02K
  • 4.48K
Message 9 of 14
@kevkdg wrote:
Hi Gary,
Many Thanks
https://www.google.com/search?q=xt8+optimal+settings+site%3Asnbforums.com
Stobbsy74
  • 172
  • 5
  • 45
Superfast
Message 10 of 14
How have you got competing wifi signals? the Hub wifi is turned off and you are just using the wifi off the XT8??, The 1st XT8 is like 12 inches from the hub and is being used instead of the hub wifi area. The 2nd Mesh unit is upstairs and is being used in mesh mode? The only difference is, that the Hub is doing the routing as opposed to the XT8? The OP asked, how to use the XT8 with the hub in router mode, I have answered the question, I didnt say it was the best way of doing it.
The wifi still acts like a mesh and devices automatically swap between nodes. The nodes still act as 1 wifi network, change a setting on 1 and they are all changed. All ethernet ports still work in access point mode and ethernet can still be used on the hub as well as each xt8 node.
The only reason I change ssids is because I dont want to manually reconnect over 20 devices to wifi.
