Ongoing issues with 1GB/Hub4?
Can someone from the forum team take a look at my connection - this is a recurrent issue that happens regularly (as I have posted about in the past) and has only occurred since I took out the 1GB connection with a Hub4 - prior to this having a 350Mb connection and a Hub3 I (surprisingly) had zero issues with my connection.
I’m getting fed up with rebooting my connection on a two/three times weekly basis just to maintain any sort of stability.
  • 11.82K
  • 925
  • 1.52K
Re: Ongoing issues with 1GB/Hub4?
What is wrong with your connection ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 24.7K
  • 1.42K
  • 3.14K
Define "issues" and "stability".
