  • 17
Message 1 of 8
Not transmitting 40mhz on 5ghz signal but will on 2.4ghz
Hi i have been trying to figure out why my internet is a lot slower than before over wifi.
i have figured out that my router is not using 40mhz width on 5ghz even though i have the setting set for it to do so. I have found if I change the 2.4ghz to 40 it will so its only a problem with the 5ghz side of things.
any suggestions?
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 8
Re: Not transmitting 40mhz on 5ghz signal but will on 2.4ghz
Don’t use 20/40 on the 2.4Ghz band
  • 7.72K
  • 614
  • 1.32K
Message 3 of 8
Never, never use 40Mhz bandwidth on the 2.4Ghz band because as there are only 3 usable channels available you will be using parts of two of these channels and greatly increase your chance of getting interference.
  • 17
Message 4 of 8
I am not using that on 2.4, I want it on the 5ghz but I was testing on 2.4 to see if it would work. I cant get it on 5ghz, it just stays at 20
 ours is the one in red
  • 17
Message 5 of 8
Still the same so we are getting low speeds.
  • 17
Message 6 of 8
Please i really just want my internet fixed now Ive been asking for help over the phone for ages and they NEVER fix the issue. I tried coming here and asking and yet nobody, wants to help to fix the issue. Constant dropout even though signal to router is Very good, and to be told its WIFI, when signal is always good over wifi connection speed has never been lower than 500mb from device to hub
ring virgin just to be told reset it, or, we are going to send a new router, or wait a few days and it will be fine.
why is virgin always so unhelpful in every department??!
  • 24.77K
  • 1.43K
  • 3.15K
Message 7 of 8
What are your wired speeds like?
What speeds are your “expecting” to receive over Wi-Fi and from what device?
  • 3.65K
  • 283
  • 513
Superfast
Message 8 of 8
It could well be a fault with the HUB so sending a new one might be the answer?
