on 04-08-2023 14:52
Hi there, so I recently had 1gb broadband installed and a free hub 5 at a good deal. In the first week of having the new gigabit broadband, I was getting the full download and upload speeds of 950mbps download and 100 upload. However, what I have noticed is that a few weeks on and the broadband has started to fluctuate again. Currently, I am getting only the following speeds. For ethernet, this is absolutely shocking. I am connected by ethernet directly to the Hub 5 so there should be absolutely no reason as to why I should not be getting the full speeds.
Please don't respond to this thread telling me to pinhole reset or any other technical simplicity as I would have already done this. I have BQM running now to find out what the issue is. I would like to also point out that this is a recurring problem for me as I experienced the same problem just 2 years ago and made a thread about it, (https://community.virginmedia.com/t5/Forum-Archive/Not-getting-advertised-100mbps-speeds/td-p/479111...)
(https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-very-intermittent-and-disconnects-...)
I really need this pinpointed if it is a technical fault in my house somewhere, or something else. I have absolutely no idea why this is happening, and why it has been happening for the past few years.
Answered! Go to Answer
04-08-2023 15:49 - edited 04-08-2023 15:54
Power levels look fine. Can you post the RS error levels Stats/table
Do you have a BQM going ?
Although you will have tested/done this... my first bet would be a bad/loose connection in the ethernet cable RJ45 connector... which usually drops everything down to <100. May be intermittent too. I have had a couple go like that in the last 2 years one of them was brand new - I suspect a shoddy manufacturer 😎
Do you also get those speeds when you boot into safe/networking mode with all other ethernet cables disconnected from the Hub and the wifi off?
on 04-08-2023 15:03
Check for a known service fault in your street via : 0800 561 0061 - it is an automated service.
Review the Hub's Upstream and Downstream stats, check for any issues with Power Levels, SNR, Errors or Upstream modulation modes.
on 04-08-2023 15:10
Hi there,
No known faults. I have posted the downstream and upstream, if anyone could have a look at it for me.
on 04-08-2023 15:38
on 04-08-2023 16:18
Wow what a simple solution jbrennan. Just swapped out that ethernet I was using with a spare and voila, the 950mbps is finally coming now. So yeah it was a cheap cable that limited it to 100mbps.
on 04-08-2023 17:16
Yep, it always the first suspect, closely followed by a dodgy network switch 😎
Glad its sorted.
on 04-08-2023 18:28
Hi @Rarr5624,
It's great to hear that this has now been resolved. Please do let us know if there's anything more that we can help you with.
