Frannmatt
Just joined
No wifi
I am having major issues with WiFi. You can not leave the room where the hub is otherwise you have no signal. The children have major issues using there smart tvs or consoles as they just buffer. We have done everything advice has said and nothing has worked even the virgin tv box in the same room as the hub losses WiFi!!!!! It is beyond a joke for what we pay. We regret leaving sky.
g0akc
  • 879
  • 81
  • 169
Well-informed
Re: No wifi
If wired connections are ok get your own router and use hub in modem mode
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
  • 22.38K
  • 2.4K
  • 3.99K
Re: No wifi
If its a wifi only issue, then on a Hub3/4, try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings and at the same time switch off "channel optimisation" Search for the "how to" on this forum
Then use a wifi scanning App to find the best wifi channels to use (just use 1,6,11 on 2.4GHz)— that often helps Hub3 users get better wifi performance - but its still no substitute for getting better kit 🙂
To address this, VM now supply “wifi pods” (not “boosters”). Pods are free to “some customers” most will be charged £5/month and they dont have enough supplies right now to provide them unless you have a demonstrable wifi issue.
At that level of investment you would soon pay off that cost by buying a "better" wireless solution that will be yours to own and use forever and which will cure all your wifi woes.
