No wifi
Had no WiFi since virgin did “updates” in my area, all green lights on my hub, tried rebooting and following the steps on the app, no luck
any ideas?
  • 6.51K
  • 491
  • 861
Hero
Re: No wifi
switch your Hub off.
Switch your device off.
Switch the Hub on.
Wait 5 minutes.
Switch your device on.
Reconnect to your wifi.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Re: No wifi
No luck
  • 15.63K
  • 1.64K
  • 2.66K
Re: No wifi
Are your ethernet connected devices working ok ?
Re: No wifi
I don’t currently have any Ethernet connected devices
  • 15.63K
  • 1.64K
  • 2.66K
Re: No wifi
If you think that you have a BB connection/speed problem, then to check this and the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, - no BB supplier guarantees those as there are so many variables outwith their control.
So you need to do it on an ethernet cable connected computer/laptop with the Hub in modem mode. Do you have one you can use - or ask a friend/neighbour to test it for you with theirs?
