I’m a new user to VM. My wifi is not working. It keeps dropping all connected devices after a few minutes.
it will connect and then say “no internet connection”, then the connection will drop, the wifi icon will disappear and then the wifi icon will re-appear 5 minutes later. I’ve turned off the hub from the wall socket and turned it on again. No luck. I’ve restarted the hub (following the guide on your website), but again, nothing. Connections are still dropped after a few minutes.
The wifi doesn’t even reach the ground floor (the hub is on the first floor.
It has been deeply frustrating moving over to VM. Your website is no help as it is circular and doesn’t give me meaningful solutions (other than turn it off and on again).
please assist?
