Message 1 of 8
No lights on super hub
I have zero lights showing on my super hub which means no internet.
All the cables are solid and the plugs working. I have been on hold for 40 minutes before being cut off and have been on hold now for another 23 minutes, and counting.
I have texted 07533051809 explaining the situation and yet heard nothing. I work from home and NEED this fixing ASAP
  • 6.51K
  • 490
  • 860
Hero
Message 2 of 8
Re: No lights on super hub
Which Hub do you have ?
Is the Hub power adaptor warm to the touch ?
Is the Hub warm to the touch ?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Message 3 of 8
It's a Hub 3.
The power adapter is warm but the hub isn't which suggests to me that the hub has died
  • 2.03K
  • 152
  • 465
Problem sorter
Message 4 of 8
Check that the Hub hasn’t been turned off via the switch on the back.
  • 6.51K
  • 490
  • 860
Hero
Message 5 of 8
You can either wait on here for one of the VM Staff to pick up the thread, this may take a few days, or phone it in to the Call Centre.
Mike Robinson
Message 6 of 8
All switches are as they should be
Message 7 of 8
I finally got through to the call centre after being on hold for two hours. I "should" receive a brand new hub on tuesday
  • 2.03K
  • 152
  • 465
Problem sorter
Message 8 of 8
Hopefully the new Hub will resolve the problem. 🙂
