on 24-07-2023 14:04
Hi there I hope I'm in the right area. Having to do this via my mobile. I had internet last night, even though it was only 5meg down load and 50meg. I have none today. I have a hub5 and it's flashing blue and when I looked into the hub it said ds scanning. I checked my cables and reset it again it's still doing the same thing. I called 150 and it made me jump through a few hoops with no success, not impressed with your virtual assistant. A real human would have sorted it out straight away or helped me better. Then I remembered I posted on this a few years ago on the forums so hopefully I can get some help from a moderator, and if someone has to phone me I'm only available in the mornings thanks for any help in advance.
Answered! Go to Answer
24-07-2023 15:56 - edited 24-07-2023 16:07
The best number to check for a fault in your street is : 0800 561 0061
If no fault is reported, you may have to be the first to call it in.
on 24-07-2023 18:09
Already done that, it says it's fine. It's the actual reporting of a problem to someone is a problem, you get the link via txt and it takes you to the same place that you've already checked and run their tests. The priority number is no use whatsoever as it takes you back through the same circle. Come on Virgin Media at least give me someone to actually talk to via a normal phone.
on 24-07-2023 19:30
Call it in as a fault on 150 or 0345 454 1111 from a non-VM phone
It'll ask you to reboot the hub (if you already - don't repeat)
You will then be cut off
Wait a couple of minutes
Call again - report a broadband fault - The system will recognise that you called before and transfer you to a person!
on 25-07-2023 12:24
Thanks I got through to a normal human being today and an engineer is coming out on Thursday. Many thanks again.
