panlid
No connection
Hi...after having our Internet strangled I upped to the 1gig package but was told I needed the new hub 4.
Since getting the new hub I am geod tting good WiFi signals but the connection drops out. This only happens on wifi. It will reconnect minutes later
I've rebooted everything but no better.
Any help much appreciated.
RedGooner
  • 1.88K
  • 66
  • 248
Super solver
Re: No connection
2.4GHz or 5Ghz Wifi range.
Does the wired also drop connections.
Change the WIFI channels.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
  • 15.49K
  • 664
  • 1.52K
Re: No connection
Stop using ISP gear for wifi and get a better wifi connection with 1Gb ports router and the hub in modem mode.
