No connection
so we phone virgin because the tv dont work around 7 they answer the phone at half 8 an talk about getting someone out to give us another virgin box then phone lines go down at 8 so we can phone again and boom internet and phone gets cut off by these geniuses and no way to contact them for help.
  • 15.74K
  • 1.65K
  • 2.69K
Re: No connection
Have you checked for “known network faults”?
As well as trying the “check service,” Area status webpage", there is also a Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level (that may not be listed on the Area Status web page which usually covers 1000’s of customers) - that may give you more info, but even that wont cover problems affecting just a few customers.
If nothing shows on there, try calling it in again as a fault (on 150 VM line - or 0345 454 1111 others) and see what they say when they test your connection and if possible, get a fault reference number – the UK call center is still picking up and 08.00 is the best time to call
If there is a known fault there is nothing to be done until they get it fixed.
