Message 1 of 5
No connection in Cambridge
I would like to find out about any issues people are having in the Cambridge area with Virgin.  I work from home but my broadband has been down all day.  Luckily we have a back up network but the speed is very low.  I have booked an engineer, who is coming out on Saturday.  Between then and now I some very urgent work which needs doing.  Virgin - this is not good enough.  I would like to know when things are going to be sorted.
  • 24.64K
  • 1.42K
  • 3.14K
Message 2 of 5
Re: No connection in Cambridge
Presumably by Saturday when the engineer attends.
I’m not sure what more you want them to add at this stage?
  • 17.34K
  • 1.82K
  • 3.02K
Message 3 of 5
Have you checked?
As well as trying the “check service,” Area status webpage", there is also a Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level (that may not be listed on the Area Status web page which usually covers 1000’s of customers) - that may give you more info, but even that wont cover problems affecting just a few customers.
If nothing shows then the engineer will sort it. Note that if there is still a "known problem" that engineer visits are auto-cancelled until it is fixed (makes sense really).
  • 6
Message 4 of 5
It has been down in Cambridge for hours. Status says fix by 15:00 but it is past that. This has been happening a lot recently. Time to change provider
  • 24.64K
  • 1.42K
  • 3.14K
Message 5 of 5
The times quoted as estimated fix times, not firm-set ones
