CarlaG
Message 1 of 7
No WiFi
Your phone lines say no issues in the WF12 area,
your site says this:
 so which is it? Because I can’t go on net flix or use my phone WiFi, can’t do anything.
sad that having issues already and I’ve not even been with your for a month yet.
  • 6.79K
  • 591
  • 1.78K
Message 2 of 7
Re: No WiFi
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page
CarlaG
Message 3 of 7
Re: No WiFi
I literally said in the post above, your phone line said no issues.
so what’s going on please?
  • 6.79K
  • 591
  • 1.78K
Message 4 of 7
Re: No WiFi
It is not "my" phone line.  This is a Community support and most of the replies will be from non VM employees.  We do try our best to assist 😉
It will be a day or two before a VM Mod will reply in most cases.
If you need is urgent, then I suggest you just keep ringing VM.
CarlaG
Message 5 of 7
Re: No WiFi
My apologies I did think you were a VM employee. Thanks for the replies
  • 6.79K
  • 591
  • 1.78K
Message 6 of 7
Re: No WiFi
No apology needed.  🙂
John_GS
  • 15.63K
  • 796
  • 1.46K
Message 7 of 7
Re: No WiFi
Hi @CarlaG
Apologies for the WiFi issue. I have checked the system and you were affected by a fault which is now fixed.
I hope this means everything has been resolved, do pop back if you ever need anything.
Best wishes,
John_GS
