No WiFi signal
kingfisher2
I have just spent 3 hrs on phone to Virgin, in all spoke to at least 4 people, the fact I have internet on desktop and television via ethernet cable is working OK. My laptop and mobile phone which are on WIFI are not working. Have been through may options with no joy. Each time I ring have to go through all security options. Have been cut of a couple of times. Tried to ring to ring again never got through. To me it's as simple as my hub is not giving out a WIFI signal. At my wits end as to where to go next. What a terrible company they are.
1 ACCEPTED SOLUTION
Accepted Solutions
Hubs are cheap best not to use its wifi get this instead and use hub in modem mode
https://www.amazon.co.uk/ZYXEL-SOHO-NBG7510-AX1800-ROUTER/dp/B09XJ7PHWZ/ref=sr_1_6?crid=1GW0SE7IFB83...
2 REPLIES 2
John_GS
Hi @kingfisher2
Very sorry to hear of any WiFi issues.
I've done a check and no issues are showing to be causing this.
Please download the Connect App for me. When downloaded, you'll be able to do a wireless scan in the property, this will check and identify any coverage issues. It'll optimise them where possible. If it can't and a Pod needed, you'll be prompted to order.
Please keep me posted how you get on.
John_GS
