Sign in
Sign out
on 09-02-2023 11:28
Hub 3 installed a few days ago and all working except Epson printer XP202. Worked OK with previous broadband supplier. The printer does not have a control panel so at a loss on how to change SSID and password? Any suggestions would be appreciated.
on 09-02-2023 11:38
The manuals for the Epson XP202 are here :-https://www.epson.co.uk/en_GB/support/sc/epson-expression-home-xp-202/s/s1096Find the process that was followed to connect to the last broadband provider and repeat it with the Hub 3.It might be a "PAIR WPS" process that needs to be followed.
Or there may be manual methods via USB or network cables.Our Epson is network cabled - very simple and reliable.
on 09-02-2023 12:10
Have tried your suggestions but no joy.
I can use a cable but the printer is not near the laptop so need to get WiFi working somehow
Many thanks for your help
DAVENIC
on 09-02-2023 12:23
there are many FAQs herehttps://www.epson.co.uk/en_GB/support/sc/epson-expression-home-xp-202/s/s1096this one is WiFi setup over USBhttps://www.epson.co.uk/en_GB/faq/KA-01615/contents?loc=en-us
on 09-02-2023 15:50
I managed to eventually get the printer connected to the Virgin WiFi using the set up wizard and usb cable.
Very hit and miss but got there in the end.
