NickyB100
No WPS Pair light on Hub
When I press the pair button on my hub the light doesn't come on showing the pair symbol.  Any ideas?
  • 1.74K
  • 109
  • 399
Super solver
Re: No WPS Pair light on Hub
From the Hub's menus at http://192.168.0.1
Disable then Re-Enable WPS
The navigation is similar to :   Hub menu >>> Advanced settings >>> Wireless >>> WPS
NickyB100
Thank you.  We reset the hub, I didn't think of doing that, and it worked.
