Jasonmc2349
Message 1 of 9
No 2.4 signal
Hi everyone
I have been having slow internet and having trouble getting 2.4 for a few days now. Trying to check it out with the app and it just keeps telling me there’s a problem and can’t check. So i do a reboot and still the same 😡 I’ve tried the small reset button on the back and still the same. Any ideas please 🙏🏼
cheers Jason
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 9
Re: No 2.4 signal
Hiya - Resets can be a bit tricky.
FOllow this procedure:
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
Jasonmc2349
Message 3 of 9
Re: No 2.4 signal
I tried that again yesterday and still the same. I get the same message saying something not right
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 4 of 9
Re: No 2.4 signal
SOunds like a knackered hub!
VM staff should be along shortly!
Jasonmc2349
Message 5 of 9
Re: No 2.4 signal
Hi Lotharmat
thanks for trying to help it’s appreciated
  • 23.98K
  • 2.54K
  • 4.35K
Message 6 of 9
Re: No 2.4 signal
What Hub model is it?
Jasonmc2349
Message 7 of 9
Re: No 2.4 signal
Hi John
it’s a hub 3
  • 3.19K
  • 249
  • 694
Message 8 of 9
Re: No 2.4 signal
Are you only using the app to diagnose this problem?  Can you connect with a laptop directly via cable and get to the Hub's admin pages?
  • 23.98K
  • 2.54K
  • 4.35K
Message 9 of 9
Re: No 2.4 signal
If you do as adduxi suggests look on the wireless page that both 2.4 and 5 frequencies are still both active (turn off and on to be sure) also check that the SSID's are what you expect them to be - are they still the same (as per factory) or had you separated them by renaming the SSID's? if not try that, it sometimes helps a Hub3 wif performance.
