Nintendo switch not connecting to wifi since reboot
Since rebooting my wifi hub 4 now my switch will not connect back to the wifi!
  • 3.89K
  • 625
  • 851
Community elder
Re: Nintendo switch not connecting to wifi since reboot
Hi Jr_Supastarr,
Have you tried rebooting the Nintendo Switch?
Was your Switch installing an update as that would prevent a network connection until completed?
Had you altered any settings on the hub4 prior to the reboot, such as changing the SSID or password? If so the hub may have changed them back to the default.
What does the Connection Status say when you click on Internet > Internet Settings on the Switch?
If it says not connected then click on Internet Settings, it will search for networks, and should show your registered networks at the top, and further down Networks Found.
If there isn't a tick next to your registered network(s) then press the A button. You will then have 3 choices
Connect to this network  - so you can re-enter your password
Change Settings - you can make any manual adjustments needed here to match any you made on your hub, also Connect Automatically, or if you've hidden the hub then you can select Connect to Hidden network
Delete Settings - if you delete the settings you can set them up again manually
Dave
You are a life saver!
I had recently made some changes to my hub settings to counteract some issues with my sky q.
so it was a case as you recommended to delete the saved settings and just search for my network again and reconnect to it.
  • 3.89K
  • 625
  • 851
Community elder
Hi JR_Supastarr,
Thanks for the update, pleased it's all working now.
We often forget that we've made changes and don't notice until something stops working
Dave
