New Hub and 2.4ghz wifi extenders
Hello.
I recently was upgraded to the new Virgin Hub.
The wifi extender we were using from Yezala only uses 2.4ghz. I can see the wifi extender on the network, but it will not accept the hub password. I expect it is to do with no hub differentiation from 2.4 to 5ghz
Options:
1. Get the Yezala extender to see the hub's 2.4 address. Would this mean creating separate 2.4 and 5ghz addesses? How do I do this?
2. Buy a VM wifi extender using the powerlines (or another brand). Is the VM one good> Or are there other, better brands?
3. Some other option. Mesh, a different extender - any recommendations?
Please could the answers be really simple and clear
Many thanks
  • 24.56K
  • 1.41K
  • 3.12K
Re: New Hub and 2.4ghz wifi extenders
You would need to reset the network settings on the extender and re-join it to the hub.
But yes a mesh system will be 1000 times better
Many thanks
Could you recommend a mesh system that works well with the new Virgin modem?
Thanks again
  • 24.56K
  • 1.41K
  • 3.12K
BT Whole Home, TP-Link Deco “M” series, Amazon Eero.. depends on your budget and requirements for coverage.
