Message 1 of 9
New Hub 4 Problem
Help! Had the new hub 4 for a week now and the WiFi drops out all the time. Can’t even stream music via WiFi anymore without buffering etc. Wired I get over 100mb and sometimes WiFi I get 100mb but then it constantly drops to almost nothing. Anyone any ideas what I can do? I previously had the hub 3 with very few issues at all for years now.
Tags (1)
  • 11.83K
  • 925
  • 1.52K
Message 2 of 9
Re: New Hub 4 Problem
What is your contracted speed ?
How far from the Hub is the device that is having the problems ?
Mike Robinson
Message 3 of 9
100mb speed which I get wired from the hub. Issue is when it sends out the WiFi signal. Having problems all over the house, even in the same room to a google nest some 2 meters away! Do you think a basic WiFi booster would help?
Incidentally I haven’t returned the old hub 3 yet so I’m thinking of just going back to that instead!
  • 11.83K
  • 925
  • 1.52K
Message 4 of 9
If you feel that it would do any good it would certainly be worth while.
But
They gave you a Hub 4 for a good reason, I don't know the reason but they wouldn't have done it for no reason.
If you stick with the Hub 4 and get your own more powerful Wi-Fi broadcasting equipment I doubt you will have any more problems.
Mike Robinson
Message 5 of 9
Any recommendations on better WiFi broadcasting equipment? And I’m talking budget level really. Thanks in advance
  • 24.72K
  • 1.43K
  • 3.15K
Message 6 of 9
There’s little point cheaping out on routers or a mesh.
You'll need to spend £100 minimum.
  • 5
Message 7 of 9
I've had similar hub 4 problems. Why is get a new router (at your own expense) a good option? Given that we pay a lot of money for Virgin's equipment and service, shouldn't a new hub work effectively without costly extras? It would make more sense for Virgin to work on making hub 4 better, particularly as many people are saying that hub 3 didn't cause problems and hub 4 is meant to be an improvement on that.
  • 24.72K
  • 1.43K
  • 3.15K
Message 8 of 9
You don’t pay for Wi-Fi though.
  • 11.83K
  • 925
  • 1.52K
Message 9 of 9
As for recommendations, only you know the ...
Budget,
Environment,
Workload the device will have to support.
Have a read of online PC and Networking mags to get an idea.
Mike Robinson
