Message 1 of 7
New FTTP connection, occasional drop outs
Had an FTTP VM connection put in recently, for the first week or so no issues but today it started dropping out and having checked the stats on the SH3 I'm concerned that the error rate seems incredibly high. The error counts are only within a few minutes of having restarted the SH3.
Cable Modem Status
Item Status Comments
402750000
Locked
Ranged Upstream Channel (Hz)
39399996
Locked
Provisioning State
Online
1 402750000 -2.7 27 256 qam 25
2 194750000 -0.9 25 256 qam 0
3 202750000 -1 25 256 qam 0
4 210750000 -1.2 25 256 qam 0
5 218750000 -1.2 25 256 qam 0
6 226750000 -1.2 25 256 qam 0
7 234750000 -1.5 25 256 qam 0
8 242750000 -1.7 25 256 qam 0
9 250750000 -1.9 25 256 qam 0
10 258750000 -2 26 256 qam 0
11 266750000 -2 26 256 qam 17
12 274750000 -2.2 26 256 qam 18
13 282750000 -2.4 26 256 qam 19
14 290750000 -2.5 26 256 qam 20
15 298750000 -2.4 27 256 qam 21
16 306750000 -3 26 256 qam 22
17 314750000 -2.9 26 256 qam 23
18 322750000 -2.7 26 256 qam 24
19 410750000 -2.7 27 256 qam 26
20 418750000 -3 27 256 qam 27
21 426750000 -3 27 256 qam 28
22 434750000 -3 27 256 qam 29
23 442750000 -3.2 27 256 qam 30
1 Locked 27.4 6649626 194551
2 Locked 25 111 5251530
3 Locked 25.1 139 5251649
4 Locked 25.1 132 5253857
5 Locked 25.1 138 5254717
6 Locked 25.1 148 5251109
7 Locked 25.3 150 5255963
8 Locked 25.5 434 5256537
9 Locked 25.9 35229 5216470
10 Locked 26.4 1234491 4023746
11 Locked 26.7 2376464 2882536
12 Locked 26.7 2418218 2841605
13 Locked 26.9 3436333 1823789
14 Locked 26.9 3854540 1398029
15 Locked 27 4110305 1151776
16 Locked 26.9 3857217 1404926
17 Locked 26.8 3374729 1891258
18 Locked 26.8 3069582 2197471
19 Locked 27.3 4886080 372591
20 Locked 27.6 5140149 83043
21 Locked 27.4 5052565 198014
22 Locked 27.3 4909621 350443
23 Locked 27.2 4644228 614403
1 39399996 4.05 5120 64 qam 10
2 25800000 4.05 5120 64 qam 12
3 32599983 4.05 5120 64 qam 11
4 46200043 4.05 5120 64 qam 9
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
24/08/2020 19:40:29 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:27 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:23 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:23 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:18 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:17 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:13 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:11 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:11 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:9 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:8 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:8 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:40:5 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:39:55 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:39:55 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 19:39:53 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 611
  • 37
  • 95
Rising star
Message 2 of 7
Re: New FTTP connection, occasional drop outs
Definitely something wrong.
Your downstream signal to noise is very poor.
Check connector inside and out (had any rain recently?). Disconnect and remake the connectors check the state of each.
If that doesn't fix it the you'll need and engineer.
Do you know where your local street side cabinet is? Does that look ok?
Message 3 of 7
Had some very heavy rain last week but not much over the weekend and it's been fine until today. I will eyeball the outside connections/street cabinet tomorrow and raise with VM thanks.
Message 4 of 7
I found a loose coax in the box outside which I have now snugged up, things appear to be back to normal although more inclined to believe it was a local fault that got fixed while I was out and about today!
1 402750000 -2.7 37 256 qam 25
2 186750000 -0.7 38 256 qam 7
3 194750000 -0.9 38 256 qam 8
4 202750000 -1 38 256 qam 9
5 210750000 -1.2 38 256 qam 10
6 218750000 -1.2 38 256 qam 11
7 226750000 -1.2 37 256 qam 12
8 234750000 -1.5 38 256 qam 13
9 242750000 -1.7 38 256 qam 14
10 250750000 -2 38 256 qam 15
11 258750000 -2 37 256 qam 16
12 266750000 -2 38 256 qam 17
13 274750000 -2.4 38 256 qam 18
14 282750000 -2.4 37 256 qam 19
15 290750000 -2.7 37 256 qam 20
16 298750000 -2.5 37 256 qam 21
17 306750000 -3 38 256 qam 22
18 314750000 -3 37 256 qam 23
19 322750000 -2.9 37 256 qam 24
20 410750000 -2.7 37 256 qam 26
21 418750000 -3 37 256 qam 27
22 426750000 -3 37 256 qam 28
23 434750000 -3.2 37 256 qam 29
24 442750000 -3.4 37 256 qam 30
1 Locked 37.6 22 0
2 Locked 38.6 6 0
3 Locked 38.9 5 0
4 Locked 38.6 6 0
5 Locked 38.9 11 0
6 Locked 38.6 5 0
7 Locked 37.6 5 0
8 Locked 38.6 5 0
9 Locked 38.6 4 0
10 Locked 38.6 0 0
11 Locked 37.6 6 0
12 Locked 38.6 5 0
13 Locked 38.6 6 0
14 Locked 37.6 6 0
15 Locked 37.6 12 0
16 Locked 37.6 6 0
17 Locked 38.6 9 0
18 Locked 37.3 10 0
19 Locked 37.6 13 0
20 Locked 37.6 18 0
21 Locked 37.6 53 0
22 Locked 37.3 74 0
23 Locked 37.3 62 0
24 Locked 37.3 82 0
  • 3.85K
  • 178
  • 301
Message 5 of 7
Good Morning zelate,
Thanks for your post on our Community Forums and a very warm welcome to you!
Sorry to see you've been having issues with your broadband connection
How are things currently looking? Are you able to provide us with an update?
Kindest regards,
David_Bn
Message 6 of 7
It's remained stable so far since I tightened the loose connection outside so currently all good.
  • 3.85K
  • 178
  • 301
Message 7 of 7
Thanks for letting us know, pleased to hear it
Kindest regards,
David_Bn
