Albundy111
Network settings clashing
Spoiler
Hi, my broadband seems to be working fine, but when i go in to the virgin media connect app to check all is ok, i get an orange triangle with exclamation mark on my hub 3, and my 2 boosters. This never happened before. When i click on hub 3 i get the message 'your network settings are clashing with each other. First choose the settings you want to use then continue.'
I then get 2 options,
1. Security type wpa-wpa2-personal
2. Security type wpa2- personal
I have tried selecting both of these but it makes no difference which one i select, i get the message 'data incorrect', it then goes back to scan my network and gives me the 3 orange triangles again. Any help is appreciated.
  • 35.04K
  • 3.41K
  • 6.66K
Re: Network settings clashing
If its all working fine - dont worry about it. The connect App is flaky at best - just look at this forum for how many posts complain about it. You dont really need it - there is little that it does that cant be done by logging into the Hub settings and doing it from there - or using other tools.
Natalie_L
  • 6.6K
  • 235
  • 509
Hi Albundy,
Welcome to the Community and thanks for posting.
I am sorry to hear you are experiencing issues with the Connect App, we will do all we can to help.
Can you please try the following for me?
For your Apple device, you can try this: Open Settings > Tap your name > Tap iCloud > Tap Manage Settings > Tap the Connect App > Tap Delete Data.
For your Android device, you can try this: Open settings > Apps > Connect App > Storage > Clear data / Clear cache.
Pop back and keep us posted.
Nat
Albundy111
I have already tried clearing the data/cache on my android phone. It made no difference, still getting the same result.
  • 35.04K
  • 3.41K
  • 6.66K
What do you need it for ?
Natalie_L
  • 6.6K
  • 235
  • 509
Thank you for trying Albundy111.
Are you able to try the app on a different device at all?
Please also try rebooting the Hub and letting it fully load back up before attempting to connect.
Nat
