The first thing to establish is whether it's a fault with the incoming broadband, or with the WiFi from the Hub.
Check with a device connected to the Hub with an ethernet cable. If that drops out too you need to call Virgin and report a fault. If the broadband signal is stable then you need to improve the WiFi. The Hub - all models - has weak WiFi and will not give solid coverage of a whole house.
