  • 91
  • 7
  • 7
Up to speed
Message 1 of 10
Network Speeds Drop in evenings After Removal of TV equipment a few weeks ago
Hi all,
I keep experiencing slow network speeds and I am using CAT6 Ethernet cables I am on M100 and usually get 113 Down and 10 UP
recently I have been getting 20MBPS DOWN and the upload is variable but higher than 5MBPS
These issues have started after I changed services with virgin and removed the TV package so i was not sure if this could have impacted signal levels as I have a Coaxial signal booster due to my distance from the Node.
I have noticed virgin working in the area in the main Node that connects to my streets Cab so I'm not sure if it could be their either.
I have attached a BMQ below
BMQ
Just to clarify all cables are tight and connected and are in the same condition as when they were installed.
I have also just had a 20 year old Coax replaced by virgin and that solved the original problem for a long time on the outside of the house that was 20 years old.
Here are bits of information
187000000
Locked
Ranged Upstream Channel (Hz)
25799760
Locked
Provisioning State
Online
11870000005.538256 qam7
21950000005.338256 qam8
32030000004.638256 qam9
42110000004.438256 qam10
5219000000438256 qam11
62270000003.737256 qam12
72350000003.538256 qam13
82430000003.238256 qam14
9251000000338256 qam15
102590000003.238256 qam16
112670000003.938256 qam17
12275000000438256 qam18
132830000004.338256 qam19
142910000004.338256 qam20
152990000004.538256 qam21
163070000004.538256 qam22
173150000004.338256 qam23
183230000004.438256 qam24
194430000001.738256 qam25
204510000001.738256 qam26
214590000001.738256 qam27
224670000001.538256 qam28
234750000001.438256 qam29
244830000001.238256 qam30
1Locked38.93000
2Locked38.63160
3Locked38.63510
4Locked38.63960
5Locked38.94460
6Locked37.67100
7Locked38.68440
8Locked38.610960
9Locked38.618260
10Locked38.613780
11Locked38.97070
12Locked38.67630
13Locked38.95480
14Locked38.65980
15Locked38.65520
16Locked38.94670
17Locked38.67160
18Locked38.65160
19Locked38.98970
20Locked38.97950
21Locked38.911000
22Locked38.913760
23Locked38.615970
24Locked38.911390
12579976042.8512064 qam12
23940007043.8512064 qam8
34620008344.5512064 qam7
43259998143512064 qam11
1ATDMA0040
2ATDMA0020
3ATDMA0050
4ATDMA0050
  • 91
  • 7
  • 7
Up to speed
Message 2 of 10
Re: Network Slow Down After Removal of TV equipment
Sorry would not fit in post General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
SFID575970
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID575969
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
10/11/2020 16:38:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 03:20:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:25:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 16:28:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 07:25:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 20:39:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 09:24:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 17:04:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 17:04:14Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 16:34:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 00:25:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 14:30:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 12:25:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 11:50:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 12:42:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 06:56:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 11:36:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 04:54:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 13:34:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 08:17:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 91
  • 7
  • 7
Up to speed
Message 3 of 10
This is the BMQ of When issues started
This is todays BMQ
This is Live BMQ
  • 24.31K
  • 1.39K
  • 3.09K
Message 4 of 10
Duplicate post. Keep to the one thread.
https://community.virginmedia.com/t5/Networking-and-WiFi/Network-Slow-Down-After-Removal-of-TV-equip...
  • 91
  • 7
  • 7
Up to speed
Message 5 of 10
Here is new status
187000000
Locked
25800000
Locked
Provisioning State
Online
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID585270
Min Traffic Rate0
SFID585269
Min Traffic Rate0
  • 91
  • 7
  • 7
Up to speed
Message 6 of 10
Here is new status
1187000000538256 qam7
21950000004.838256 qam8
32030000004.338256 qam9
42110000003.938256 qam10
52190000003.538256 qam11
62270000003.237256 qam12
72350000002.937256 qam13
82430000002.538256 qam14
92510000002.538256 qam15
10259000000338256 qam16
13283000000438256 qam19
142910000004.138256 qam20
152990000004.438256 qam21
163070000004.138256 qam22
17315000000438256 qam23
18323000000438256 qam24
194430000001.238256 qam25
204510000001.238256 qam26
214590000001.238256 qam27
22467000000138256 qam28
234750000000.738256 qam29
244830000000.938256 qam30
1Locked38.6230
2Locked38.6330
3Locked38.6300
4Locked38.6160
5Locked38.6270
6Locked37.6480
7Locked37.6400
8Locked38.6530
9Locked38.6690
10Locked38.6520
11Locked38.6540
12Locked38.9590
13Locked38.9200
14Locked38.6470
15Locked38.9440
16Locked38.6350
17Locked38.6410
18Locked38.6260
19Locked38.9430
20Locked38.9340
21Locked38.9550
22Locked38.9450
23Locked38.6540
24Locked38.946
0
12580000042.5512064 qam12
23940000043.8512064 qam8
34620000044.5512064 qam7
43260000043512064 qam11
3ATDMA0020
4ATDMA0030
  • 91
  • 7
  • 7
Up to speed
Message 7 of 10
11/11/2020 03:42:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 91
  • 7
  • 7
Up to speed
Message 8 of 10
Ignore the first one there was a fault that is now deleted
  • 6.77K
  • 349
  • 598
Message 9 of 10
Hi RR-IT-GUY
Thanks for posting. My apologies for the delayed reply and the service issues.
I've checked the system here and cannot see any issues. I hope everything is resolved though do please let me know if you need further help
Kind regards,
John_GS
  • 3.74K
  • 214
  • 570
Community elder
Message 10 of 10
When you removed the TV box, did you leave its coax in place?  If so, disconnect it from the splitter.
