  • 16
Message 11 of 11
Re: Net speed Issues
Update:
Since my sister has no work over this weekend I had time to narrowing down and pinpoint the issues on my end.
BQM live graph should be working 24/7 - EdgeRouter 4  rule seems to have worked.
Ubiquity NanoHD AP was set to channel 48, moved it to 44 and is beaming out max speed to all devices that I have tested with many devices getting max throughput
Raspberry Pi 4 - Pi-Hole unbound server was causing  some issues and has been removed. Have set PiHole to use cloudfare and everything is working well.
EdgeRouter4 - QoS is setup and doing its job properly.
Playstation 4 Pros are getting max throughput. Games are downloading at speeds of up to 20mb a sec again.
PC Steam downloaded and installed a 13 gig game in 4 min at a stable 24-27mb a sec
Tablets/Smartphones/Laptops and Smart TVs are all loading 4k and 1080/60 with minimal buffering on Twitch/YouTube/Netflix/BBC/Disney
All speed tests I have performed over speedtest.net and testmy.net are showing 330-380 down and 35-40 up. Also Ubiquity WiFiMan app is showing similar results.
I am 100% sure the issues seemed to have come from the unbound dns server and the Ubiquity NanoHD Firmware update.
I am certain and positive everything has gone back to way I had my network pre-lockdown.
My only question is are my router stats OK? is there any way to lower the latency?
Other than that I appreciate the suggestions and replies again. Thanks
