  • 16
Message 1 of 11
Net speed Issues
Package vivid 350
I was getting speeds of 350/38 up until May.
from mid April to current day - Every week our net speeds have decreased over time.
At first it wasn't an issue as we assumed it's probably the mass influx of users and it's probably congestion in the network and we dropped to 280/29 at the start of lockdown.
Then from End of April - mid July we were renovating the whole house and barely had any time to do anything.
As above we finished 2 weeks ago, and we're all starting to get back online with about 15 devices (tablets, netbooks, consoles, desktop, smart tv's)
The speeds have dropped yet again (to around 130-150/38) and it's getting top the point where sister is working from home and gets cut up or disconnected from calls and she lets every know.
I've factory reset the router, checked all cables and the box outside the house, It was re-positioned and made sure all cables are secure, snug and tight.
Internet is stable with the odd hiccups every once in a while
I use a custom setup
SHub 3.0, Edgerouter 4, Ubiquiti NanoHD, Pi-Hole DHCP/DNS, QoS settings in place - Nothing has changed, been touched or messed around with since last year.
I've had uptime on each device for 50+ days and I reboot them once in a blue moon.
Any help is appreciated.
  • 6.75K
  • 505
  • 884
Legend
Message 2 of 11
Re: Net speed Issues
Your images need authorising before they become visible for general viewing.
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 16
Message 3 of 11
Hi Mike.
Thanks for the response
BQM Link
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u+voc-b.cm
SFID117618
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID117617
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
1394000003.85512064 qam6
2462000003.85512064 qam5
3326000003.85512064 qam7
4258000003.825512064 qam8
3ATDMA0000
4ATDMA0000
1139000000-1.737256 qam1
2147000000-1.237256 qam2
3155000000-137256 qam3
4163000000-137256 qam4
5171000000-137256 qam5
6179000000-137256 qam6
7187000000-137256 qam7
8195000000-1.237256 qam8
9203000000-1.537256 qam9
10211000000-1.737256 qam10
11219000000-237256 qam11
12227000000-237256 qam12
13235000000-2.437256 qam13
14243000000-2.737256 qam14
15251000000-337256 qam15
16259000000-337256 qam16
17267000000-337256 qam17
18275000000-3.237256 qam18
19283000000-337256 qam19
20291000000-3.237256 qam20
21299000000-3.237256 qam21
22307000000-3.437256 qam22
23315000000-3.536256 qam23
24323000000-3.536256 qam24
1Locked37.350
2Locked37.650
3Locked37.640
4Locked37.350
5Locked37.370
6Locked37.650
7Locked37.660
8Locked37.350
9Locked37.650
10Locked37.650
11Locked37.660
12Locked37.660
13Locked37.370
14Locked37.3110
15Locked37.360
16Locked37.370
17Locked37.350
18Locked37.640
19Locked37.660
20Locked37.3120
21Locked37.360
22Locked37.350
23Locked36.660
24Locked36.600
  • 16
Message 4 of 11
Here's a current speed test. Only about 5 devices on the network atm. https://testmy.net/db/h18BGOYq4
Service status - Good in my area with no issues
Can't do a direct link to the router as my sis is working and I don't want to interfere.I should be able to check when she finishes and post my results asap later.
Other (useless) info: I have the edgerouter4, Raspberry Pi4 Pi-Hole, Ubiquity Nano HD connected to a switch
All devices are on 5Ghz band on the NanoHD AP. None connected on ethernet
Every device gets near enough 100% link speed/connection on floor 2/3 with the 1st dropping to 70-85
At max speed my PS4 Pro when downloading a game would reach 20mb a sec throughput. Downloading 80 gig games would take 45mins. Now its between 4-10 and can sometimes take up to an hour for a 3gig patch
PC Steam would download at 27-35mb a sec. Now it's about 10-15mb on and off with spikes to 30mb a sec.
Playing BattleField 5 on my PC with 32-39 ms ping. I don't have lag or haven't been disconnected in the last 30 games I have played over the last week
Same with Destiny 2 on my brothers PS4 Pro. He's got stable and great connection with no lag.
Snapchat, WhatsApp, YouTube, Netflix, browsing net on all devices is all OK
All the same static IP's are used on Router, AP and Pi-Hole with mac filtering
All the equipment is in the same room when I was getting max speeds and as I've stated before - no settings have been altered or changed.
  • 6.75K
  • 505
  • 884
Legend
Message 5 of 11
Can you do a couple of speed tests at speedtest.net, these are the tests that VM accept then post links to the results onto here.
For speed tests, only use a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Have you set up a BQM yet ?
Mike Robinson
  • 16
Message 6 of 11
The BQM link is in the first post near the top
forgot this
Item Status Comments
139000000
Locked
Ranged Upstream Channel (Hz)
39400099
Locked
Provisioning State
Online
I'll do the speedtest later when I've got time.
Sis said she gets disconnected on calls after the 5 min mark, this doesnt happen on brothers WiFi (vivid 200) when she connected to that network.
  • 16
Message 7 of 11
I disconnected my custom setup and went back to router mode on the SHub 3.0 and booted everyone else off the network
Plugged cat6 cable into my gaming laptop and did 3 separate speed test from speedtest.net like you asked
Here are the results
Speed Test 1
Speed Test 2
Speed Test 3
Surprisingly everything is looking solid from VM side and the SHub from the results.
Like I said before I have a stable connection and reboot once in a blue moon. But I can't figure out why the increments off speed loss over the last 3 months.
Also the BQM has updated with some new info.
Advice would be appreciated from yourself again or anyone.
Thanks again in advance
  • 6.75K
  • 505
  • 884
Legend
Message 8 of 11
Is your BQM running to your router or the Hub. It is showing all red which to me means the device it is pinging isn't responding to ping or it is powered off.
Mike Robinson
  • 16
Message 9 of 11
I think it's the router but it's getting blocked by the firewall. I've created a ruleset but it doesn't seem to be working. So l've bypassed my custom DNS and went with cloudfares and the BMQ graph is working when I have my PC running (As of this post it's half red and showing results too).
I think I've found half a solution and that's my AC NanoHD.
When I get a new device or person wants to get into my network I've set it to only have a whitelist cause of the MAC filter.
Only reason I bring this up as I only log onto the AC in rare instances and when I do, I get prompted to update to the latest firmware which I did prior to making this thread asking for help on my issue.
After doing the laptop/ethernet test yesterday and seeing no issue with the SHub (not sure if it's ok or not).
decided to check the AP settings and looking up any issues with the firmware. Someone suggested the last couple firmwares were detrimental and they downgraded to last year's final firmware and avoid the 3 that came out this year.
So I did downgrade and I went from 60-85 to 150-190 - avg of 170mbps
Issue is that I remember this firmware hitting max speeds last year too.
I'm still open to any more suggestions. Thanks again for the replies.
Note
Im on phone. sorry for any mistakes and formatting issues  if they occur
  • 16
Message 10 of 11
I switched off my pc and took a screenshot of the BQM just incase
