on 10-07-2023 17:19
Had WiFi setup about 2 weeks ago and having lots of problems and can't work out how to speak to someone to resolve
The wifi seems good in the room that the router is in. It was very poor elsewhere. I upgraded my account and got a pod. This has improved things a bit but the service is still not good.
Answered! Go to Answer
on 10-07-2023 17:44
The VM Pod's placement is critical to its success, the VM Pod needs to be place where there is a signal from the Hub for it re-broadcast. The classic error is to place a VM Pod in an office or bedroom where the Hub's signal is far too weak or not available to be re-broadcast.
on 10-07-2023 17:44
on 10-07-2023 18:22
Thanks for the reply.
It's a few meters away from the router and gets decent signal. (It's where I had the sky booster when I was with them)
on 10-07-2023 18:24
Grrr, I didn't want to mark this as solved, just to say the reply was helpful.
Is there any way to contact someone at virgin? This is pretty aggravating having to bug people on a forum to get help with their product.
on 11-07-2023 00:49
Hi Bb1889
If you need additional pods you can order them by logging into /my-virgin-media , as per the info below from https://www.virginmedia.com/wifi-max ?
11-07-2023 07:19 - edited 11-07-2023 07:22
Go ahead and mark a "Not a Helpful Answer".
VM Pods are free on some subscriptions, but when they are not free they cost £8 per month each it is less costly to buy your own Wireless Repeaters. Dual Band Wi-Fi repeaters ( like a TP-LINK AC750 ) begin at £23 each in Argos / Amazon etc and work with any ISP.
on 11-07-2023 12:25
Hi @Bb1889 thanks for your post here although we're sorry to hear of the concerns you've raised with your WiFi performance.
We can see that you have recently reached out to us via other methods than here, but we hope you have been provided with at least an update on what is happening.
If you do need any further help going forwards, please let us know!
Many thanks
on 11-07-2023 13:56
Just to clear any misunderstanding, if you have to pay for the wifi pods on WiFi max then they are £8 per month in total, not £8 per month each
