Need help with port forwarding HUB5
Anne-Ruddick
Can someone tell me how to forward these ports on HUB 5 as I’ve tried to do it but don’t know how,  Ports to Forward: TCP: 53, 80, 3074  UDP: 53, 88, 500, 3074, 3544, 4500
8 REPLIES 8
carl_pearce
Community elder
Example:
I am asking as I don’t get how to actually do it, I need to do this: Ports to Forward: TCP: 53, 80, 3074  UDP: 53, 88, 500, 3074, 3544, 4500
but I don’t know at all how to do it from this like the ip and stuff
Well I guess VM have failed to make router mode simple then, people just expect it to just work.
Use modem mode with just that device and ohh look it just works.
Google how my internet works and NAT and router and  port forwarding and start learning today  but you see VM had to make trouble by doing router mode if they just stuck to modem mode then the problem for NAT routers like this will be passed on to the 3rd party forum for support.
What's the IP address of the device you are port forwarding to?
You can only forward to a port to a single device.
They likely only need to forward UDP 3074
Why, oh why, do you need to forward port 53 - DNS?
Looks very like XBox live ports to me.  l think @legacy1  is correct with just one port needed?
However Portforward.com is a good place to start.
Blame consoles and game dev that don't know what ports are coming or going
