on 13-08-2023 00:51
Good morning,
My hub needs relocating as the closest electrical socket is too far away and currently the only way to use the hub is to stretch an extension lead across my front door. We tried lifting it up to a shelf over the door as a temporary measure but the supplied coax cable is too short to reach. There is a degree of urgency from my point of view - I'm a wheelchair user so I'm having to unplug it every time I come in and out of my house or answer the door. Is this going to cause any issues or damage to the hub if I need to do this until it's moved? I am hard of hearing and can't call , I wondered if someone can please book an appointment? I understand that there is a charge.
Thank you
Answered! Go to Answer
13-08-2023 15:44 - edited 13-08-2023 15:46
A VM person will be along soon to help you out.
Or you can call it to book a move - it will cost £25 - although you might be able to get that waived due to your mobility issues But I realise your hearing difficulties may prevent you doing that - ask a friend/relative/carer to make the call for you from your phone?
on 13-08-2023 15:53
Hi @mrs_goblin
Thanks for posting on our community forum and a big warm welcome with this being your first post here.
I'll drop you a private message now to collect some more information and we'll have this resolved for you. Keep an eye on your inbox for a message from myself
on 15-08-2023 02:06
Thank you for your help 😀
