bendavid
Need A Guru to have a look at this BQM and Hub Logs If Possible
BQM
Status;
Cable Modem Status
Item Status Comments
Cable Modem Status Online DOCSIS 3.1
Primary downstream channel Locked SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels 31 4
DOCSIS 3.1 channels 1 0
DownStream;
3.0 Downstream channels
Channel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
25 330750000 -1.500000 37.355988 QAM256 25
32 418750000 -2.900002 36.386890 QAM256 32
33 426750000 -3.799999 36.386890 QAM256 33
34 434750000 -3.200001 36.386890 QAM256 34
4 162750000 1.799999 37.636276 QAM256 4
5 170750000 1.700001 37.636276 QAM256 5
6 178750000 1.400002 37.355988 QAM256 6
7 186750000 0.200001 37.355988 QAM256 7
8 194750000 0.299999 37.355988 QAM256 8
9 202750000 0.500000 37.355988 QAM256 9
10 210750000 0.700001 37.355988 QAM256 10
11 218750000 0.900002 37.636276 QAM256 11
12 226750000 1.000000 32.584778 QAM256 12
13 234750000 0.799999 37.355988 QAM256 13
14 242750000 0.200001 37.636276 QAM256 14
15 250750000 0.299999 37.636276 QAM256 15
16 258750000 -0.599998 37.355988 QAM256 16
17 266750000 0.099998 37.636276 QAM256 17
18 274750000 -0.099998 37.636276 QAM256 18
19 282750000 -0.099998 37.636276 QAM256 19
20 290750000 -0.299999 37.355988 QAM256 20
21 298750000 -0.299999 37.636276 QAM256 21
22 306750000 -0.500000 37.636276 QAM256 22
23 314750000 -1.000000 37.355988 QAM256 23
24 322750000 -1.299999 37.636276 QAM256 24
26 370750000 -2.299999 36.609653 QAM256 26
27 378750000 -2.500000 36.386890 QAM256 27
28 386750000 -1.799999 36.844463 QAM256 28
29 394750000 -2.900002 36.386890 QAM256 29
30 402750000 -2.400002 36.609653 QAM256 30
31 410750000 -3.200001 36.386890 QAM256 31
Channel Lock Status RxMER(dB) Pre RS Errors Post RS Errors
25 Locked 37.355988 109 0
32 Locked 36.386890 31 0
33 Locked 36.386890 35 0
34 Locked 36.386890 37 0
4 Locked 37.636276 1795 3 1307
5 Locked 37.636276 788 2041
6 Locked 37.355988 1735 6 241
7 Locked 37.355988 6 0
8 Locked 37.355988 5 0
9 Locked 37.355988 3 0
10 Locked 37.355988 16 0
11 Locked 37.636276 28 0
12 Locked 32.584778 4475 26 4
13 Locked 37.355988 11 0
14 Locked 37.636276 28 0
15 Locked 37.636276 32 0
16 Locked 37.355988 41 0
17 Locked 37.636276 17 0
18 Locked 37.636276 9 0
19 Locked 37.636276 35 0
20 Locked 37.355988 48 0
21 Locked 37.636276 92 0
22 Locked 37.636276 128 0
23 Locked 37.355988 159 0
24 Locked 37.636276 163 0
26 Locked 36.609653 76 0
27 Locked 36.386890 90 0
28 Locked 36.844463 82 0
29 Locked 36.386890 93 0
30 Locked 36.609653 66 0
31 Locked 36.386890 66 0
3.1 Downstream channels
159 96 4K 1880 QAM2048 759
Channel ID Lock Status RxMER Data(dB) PLC Power(dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159 Locked 37 -6.1 8078657 4
UpStream;
3.0 Upstream channels
Channel Frequency(Hz) Power(dBmV) Symbol Rate(ksps) Modulation Channel ID
1 60300000 44.520599 5120 KSym/sec 64QAM 9
2 39400000 45.270599 5120 KSym/sec 64QAM 12
3 46200000 45.270599 5120 KSym/sec 64QAM 11
4 53700000 43.770599 5120 KSym/sec 64QAM 10
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 0 0
4 US_TYPE_STDMA 0 0 0 0
NetLog;
Mon Apr 19 20:47:04 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:47:12 2021 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:47:27 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:47:42 2021 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 20:47:51 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:48:34 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 20:49:00 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:49:11 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 20:49:22 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:49:53 2021 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 20:50:07 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:50:07 2021 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 20:50:40 2021 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 20:50:43 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Mon Apr 19 20:50:47 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 3; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 21:39:43 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Mon Apr 19 21:43:04 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 21:51:58 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Mon Apr 19 22:01:46 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 22:40:38 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Mon Apr 19 22:44:17 2021 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Apr 19 22:52:53 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Mon Apr 19 23:19:00 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 23:37:36 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Mon Apr 19 23:38:49 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Mon Apr 19 23:49:52 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 00:02:40 2021 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 00:40:17 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 00:42:01 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 00:52:33 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 00:54:02 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 01:40:14 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 01:52:01 2021 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 01:52:29 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 02:37:59 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 02:50:14 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 03:37:57 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 03:50:13 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 04:37:35 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 04:49:50 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 05:38:02 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 05:42:34 2021 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 05:50:18 2021 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;
Tue Apr 20 06:22:12 2021 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Tue Apr 20 06:38:47 2021 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;
Tue Apr 20 06:39:35 2021 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA
Andrew-G
  • 6.06K
  • 1.07K
  • 2.56K
Re: Need A Guru to have a look at this BQM and Hub Logs If Possible
Downstream power looks a touch too low on your DOCSIS 3.1 downstream channel, the range of power levels across other downstream channels looks too wide to me at 5.6 dBmV (you'll see the uncorrected post-RS errors are correlated with your higher power levels) , and the signal to noise ratio is too low on channel 12, which looks like an RF noise ingress issue.  If all of the coax connections between hub and wall are good, and a restart doesn't sort this out (which I doubt it will) you'll need a technician visit to sort it out.  I'll flag for the forum staff to advise on that.
Zak_M
  • 3.4K
  • 213
  • 339
Hello @bendavid
Welcome back to the forums and thank you for taking the time to post.
Sorry to hear that you have had some issues with your broadband.
I have taken a look over everything, It seems as though you have an issues with your downstream power levels.  I have taken the opportunity to book an engineer for you, please check your online account ASAP and let me know that you are happy with the time and date.
Kind regards,
Zak_M
