hammic
  • 120
  • 29
Up to speed
Message 1 of 10
NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism
My SuperHub 3 started acting strange tonight.  First I completely lost the Wi-Fi, then the green Wi-Fi light on the SH3 started blinking about twice a second until I rebooted it.  I could still access the internet on my wired computers while the Wi-FI was off and the light flashing.  Very odd.
I checked 192.168.0.1 in Network Log and found this message, which was when my troubles started:
NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
With the SuperHub now restarted, all seems to be working normally again.  But is this perhaps a symptom of an underlying issue?
hammic
  • 120
  • 29
Up to speed
Message 2 of 10
Re: NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism
Cable Modem Status
Item
Status
Comments
139000000
Locked
Ranged Upstream Channel (Hz)
49600000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
7.1
38
256 qam
1
2
147000000
6.9
38
256 qam
2
3
155000000
6.8
38
256 qam
3
4
163000000
6.9
38
256 qam
4
5
171000000
6.8
38
256 qam
5
6
179000000
6.8
38
256 qam
6
7
187000000
6.6
38
256 qam
7
8
195000000
6.4
38
256 qam
8
9
203000000
6
38
256 qam
9
10
211000000
5.8
38
256 qam
10
11
219000000
5.6
38
256 qam
11
12
227000000
5.5
38
256 qam
12
13
235000000
5.1
38
256 qam
13
14
243000000
5
38
256 qam
14
15
251000000
4.8
38
256 qam
15
16
259000000
4.8
38
256 qam
16
17
267000000
4.4
38
256 qam
17
18
275000000
4.6
38
256 qam
18
19
283000000
4.5
38
256 qam
19
20
291000000
5.3
38
256 qam
20
21
299000000
5.5
38
256 qam
21
22
307000000
5.8
38
256 qam
22
23
315000000
6
38
256 qam
23
24
323000000
6.4
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
8
0
2
Locked
38.6
6
0
3
Locked
38.9
6
0
4
Locked
38.9
6
0
5
Locked
38.9
0
0
6
Locked
38.9
4
0
7
Locked
38.6
5
0
8
Locked
38.9
6
0
9
Locked
38.6
8
0
10
Locked
38.9
4
0
11
Locked
38.6
6
0
12
Locked
38.6
6
0
13
Locked
38.9
6
0
14
Locked
38.6
5
0
15
Locked
38.6
0
0
16
Locked
38.6
4
0
17
Locked
38.6
0
0
18
Locked
38.6
0
0
19
Locked
38.6
0
0
20
Locked
38.6
6
0
21
Locked
38.6
5
0
22
Locked
38.9
6
0
23
Locked
38.6
2
0
24
Locked
38.9
5
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
49600000
40.8
5120
32 qam
1
2
43100000
40.8
5120
16 qam
2
3
23600092
41.3
5120
16 qam
5
4
30100000
40.8
5120
16 qam
4
5
36600000
40.5
5120
32 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
1
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID
197148
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
197147
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
25/02/2023 20:47:38
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2023 20:45:23
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2023 20:43:17
Warning!
25/02/2023 20:42:0
critical
25/02/2023 20:41:41
Warning!
25/02/2023 20:36:52
critical
25/02/2023 20:33:58
Error
Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2023 20:29:32
Warning!
25/02/2023 20:29:31
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/02/2023 20:16:25
Warning!
25/02/2023 11:48:19
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Matthew_ML
  • 3.56K
  • 131
  • 242
Message 3 of 10
Hey hammic, thank you for reaching out and I am sorry to hear you've been having some connection issues.
I have taken a look at our side and I can't see any major issues at all, everything is looking fine.
Your levels are very healthy, how has the connection been since Monday? Thanks
Matt - Forum Team
New around here?
  • 6.79K
  • 591
  • 1.78K
Message 4 of 10
NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism is a normal reaction from the Hub's CPU when it gets overloaded.  It restarts the kernal rather than restarting the whole Hub, as this is much quicker.
Also note your Upstream QAM's are all wrong, they should be QAM 64 on all channels.  There is a problem on the circuit and this needs fixed by a VM technician.  Reboot the Hub and see what the US reports after an hour or so.  They should all stay at 64
hammic
  • 120
  • 29
Up to speed
Message 5 of 10
https://community.virginmedia.com/t5/Forum-Archive/Slow-upload-speed-10Mbps-out-of-20Mbps/td-p/48079...
I was told about the modulation problem about 1.5 years ago in above thread.  Engineers have been out, scratched their heads and walked out without being able to fix the issue.  Seemingly the problem lies in a cabinet, however I have seen other friend's stats (who don't live in the same area as me) which show the same mixed modulations for upstream.
As far as I can tell I haven't been affected again by the original issue in this thread.  I will post my stats below, although the SH3 hasn't been restarted for a couple of days - but at least you can see how my stats look after settling down over a few days.
hammic
  • 120
  • 29
Up to speed
Message 6 of 10
Cable Modem Status
Item
Status
Comments
139000000
Locked
49600090
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
7
38
256 qam
1
2
147000000
6.8
38
256 qam
2
3
155000000
6.6
38
256 qam
3
4
163000000
6.6
38
256 qam
4
5
171000000
6.6
38
256 qam
5
6
179000000
6.5
38
256 qam
6
7
187000000
6.5
38
256 qam
7
8
195000000
6.1
38
256 qam
8
9
203000000
5.9
38
256 qam
9
10
211000000
5.6
38
256 qam
10
11
219000000
5.5
38
256 qam
11
12
227000000
5.5
38
256 qam
12
13
235000000
5
38
256 qam
13
14
243000000
4.9
38
256 qam
14
15
251000000
4.6
38
256 qam
15
16
259000000
4.5
38
256 qam
16
17
267000000
4.3
38
256 qam
17
18
275000000
4.5
38
256 qam
18
19
283000000
4.3
38
256 qam
19
20
291000000
5
38
256 qam
20
21
299000000
5.3
38
256 qam
21
22
307000000
5.5
38
256 qam
22
23
315000000
5.9
38
256 qam
23
24
323000000
6.1
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
3276
52
2
Locked
38.6
658
7
3
Locked
38.9
250
0
4
Locked
38.6
713
0
5
Locked
38.9
150
0
6
Locked
38.9
171
0
7
Locked
38.6
194
0
8
Locked
38.9
507
0
9
Locked
38.6
87335
0
10
Locked
38.6
51848
0
11
Locked
38.9
136
0
12
Locked
38.6
423
0
13
Locked
38.6
8858
922
14
Locked
38.6
459
0
15
Locked
38.6
275
0
16
Locked
38.6
97
0
17
Locked
38.6
213
0
18
Locked
38.6
153
0
19
Locked
38.6
114
0
20
Locked
38.9
100
0
21
Locked
38.6
113
0
22
Locked
38.9
78
0
23
Locked
38.9
59
0
24
Locked
38.6
53
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
49600090
40.8
5120
32 qam
1
2
43100072
40.8
5120
16 qam
2
3
23600039
41.3
5120
16 qam
5
4
30099927
40.5
5120
16 qam
4
5
36600000
40.5
5120
32 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
0
0
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID
197924
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
197923
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
BestEffort
hammic
  • 120
  • 29
Up to speed
Message 7 of 10
Time
Priority
Description
01/01/1970 00:01:45
critical
27/02/2023 22:08:15
notice
01/01/1970 00:01:49
critical
25/02/2023 20:50:11
Warning!
25/02/2023 20:48:35
critical
25/02/2023 20:47:38
Warning!
25/02/2023 20:45:23
critical
25/02/2023 20:43:17
Warning!
25/02/2023 20:42:0
critical
25/02/2023 20:41:41
Warning!
25/02/2023 20:36:52
critical
25/02/2023 20:33:58
Error
25/02/2023 20:29:32
Warning!
25/02/2023 20:29:31
Warning!
25/02/2023 20:16:25
Warning!
25/02/2023 11:48:19
Error
24/02/2023 12:31:1
critical
24/02/2023 12:29:52
Warning!
24/02/2023 12:26:49
critical
24/02/2023 12:22:55
Warning!
Sephiroth
  • 22.44K
  • 642
  • 4.01K
Message 8 of 10
The ATOM issue is well known and is due to a flaw in the Intel ATOM chip used in the Hub 3. The VM Forum Team know this full well but won’t admit it even though this flaw is fully in the public domain. Adduxi has explained the effect of the fault and VM should not be supplying this flawed to device to its customers.
So when the FT say they can’t see anything wrong in your stats, the Network Log shows something very wrong and I suspect that editorial policy prevents them from acknowledging the fact.
hammic
  • 120
  • 29
Up to speed
Message 9 of 10
@Sephiroth - I'm sure you've helped on these forums in the past, so I greatly value your input.
My SH3 is quite a few years old, is there anyway I can persuade the tech support to send me another SH3 to try?
I would have considered a SH4, but apparently they use the same Atom chipset/CPU as the SH3.  I doubt I could get a SH5, but I am tempted to badger retentions enough to see if they arrange for one to be sent out to me.
I've been a customer for nearly 25 years, since the days of NTL, so i like to think that they might help me out.  But I know that things are ran on a shoestring budget at VM these days, with what feels like the sole goal of milking the customer dry for their pensions and staff soirées.
Sephiroth
  • 22.44K
  • 642
  • 4.01K
Message 10 of 10
The Hub 4 doesn't use the flawed PUMA 6 chipset; it uses, AFAIK, the Puma 7. I've never seen an ATOM restart reported on the Hub 4. I've had ne for the past three years and not a sausage has gone wrong.
