My lad games fine using a pair of high quality "powerline adapters" and short ethernet cables to connect one to the router and the other in his room to the consoles. It can be hit and miss though depending on the property's electrical circuitry quality and the quality of Adapter. My lads cost him £90 a pair - nowadays you can get a good introductory Mesh system for that money.
Note that VM (& all other BB providers) provide a service that is guaranteed TO the Hub and what comes out from it on an ethernet cabled device. They all expressly exclude guaranteeing wifi connections - as it is so influenced by the external environment. Even BT with its glossy ad's saying wifi is “guaranteed”, also charge £10/month for that and say that if it isn’t sorted they will just give you £100 back. VM try and help with swapping the Hub (just in case!) and providing pods etc., but the reality is, that if the Hub wifi doesnt work well for you then you are far better sourcing your own wireless equipment.
I dont know if you can do this on the Hub4 - you can on a Hub3 which is that you could try separating the SSID's of the 2.4 and 5 GHz wifi bands and switching off "channel optimisation" - that often helps Hub3 users get better wifi performance - but its still no substitute for better kit.
