My router is not working well (i' ve got it 3 years!!). How do I order a replacement
After 3 years my router it doensn't work well. The Wi-Fi is down very often and my connection drop down too. Please can you let me know how I could ask for a new router from Virgin?
Thank you in advance
  • 12.14K
  • 943
  • 1.56K
Re: My router is not working well (i' ve got it 3 years!!). How do I order a replacement
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Mike Robinson
  • 12.14K
  • 943
  • 1.56K
Can you please
Mike Robinson
