on 16-07-2023 11:19
Last week my hub have red light I did everything switched off etc. but nothing helps. My hub is 4 and half years old maybe that’s why?
any helps or advice please
on 19-07-2023 20:58
Hi casper6, thanks for the message and sorry to hear that there is an issue with the broadband connection.
Can you ensure that the cables are hand tight and perform a pin hole reset?
How is the service since posting? Have things now improved?
Kind regards, Chris.
