Just joined
My Nintendo switch won’t connect to my wifi only
With virgin media app I paused my switch wifi and then it went into sleep mode and no it won’t connect to my wifi only what should I do I was thinking to get new wifi box or something
  • 11.73K
  • 915
  • 1.51K
Re: My Nintendo switch won’t connect to my wifi only
Factory reset the Hub using this exact method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
  • 24.64K
  • 1.42K
  • 3.13K
Try to unpause it in the app. It probably won’t work but try.
  • 3.84K
  • 618
  • 837
Community elder
Hi certishah,
Have you tried opening up the hubs settings by typing 192.168.0.1 in a browser then going to Advanced Settings > Security >  Mac Filtering and remove the MAC address for the paused device
Or, a factory reset of the hub - press the reset pin for 60 seconds, let it reboot and wait  10 minutes for the hub to fully set in again
Dave
