Starkn93
  • 7
Message 1 of 30
My Hub 3 has red light!
my hub 3 is in modem mode and is showing a red power light instead of the usual white power light.
It is solid red but the hub is not overheating and is kept in open space with well ventilation!
Can someone help me?
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
Message 2 of 30
Re: My Hub 3 has red light!
@Starkn93 wrote:
Modem mode = Magenta, which can appear red.
Andrew-G
  • 10.39K
  • 1.66K
  • 4.75K
Message 3 of 30
If it's in modem mode then that's normal.  Technically the colour is supposed to be "magenta", but as the LED package is a cheap and short life affair, the blue output of the RGB diode package fades and the resultant attempt at magenta looks red.  If you're worried, flick back to router mode, see what colour it is when it comes back on line.  White through to light orange are acceptable.
Starkn93
  • 7
Message 4 of 30
Sometimes when I touch it's feels hot!
Starkn93
  • 7
Message 5 of 30
Will try to change to router mode..
Just on router mode wifi keeps disconecting all the time from my devices((((
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
Message 6 of 30
Magenta.
Starkn93
  • 7
Message 7 of 30
Anyway will turn off overnight. I saw in some topics that if its hot , then it could burn!
Paulina_Z
  • 4.31K
  • 159
  • 327
Message 8 of 30
Hi @Starkn93,
Welcome to our Community Forums. Thank you for your first post, and I'm sorry to see that you're experiencing some issues with your Hub and that it is hot to the touch!
Can you confirm if your base LED Hub light is still showing as red when you switch your Hub to Router Mode?
Is your Hub placed in an open and well-ventilated area, so overheating is not caused by the area in which the Hub is kept?
Please let us know so we can help.
Thanks.
Paulina_Z
Starkn93
  • 7
Message 9 of 30
 Hi ,
I switched it today to router mode and it shows same red light(( .
It's well ventilated in a open space!
Don't know why..
Starkn93
  • 7
Message 10 of 30
Hi , @Paulina_Z
Can you please help me with this?
