on 17-11-2021 17:02
Both the HP printer & smart light bulb work off 2.4ghz… but now we have upgraded the hub we can’t connect them! Is there any way around this?
on 17-11-2021 19:34
Go into the settings on the hub and split the WiFi bands, give them names like home-2 and home-5. You can then connect them to home-2. Also turn off smart/intelligent WiFi.
on 17-11-2021 22:30
I installed a new Hub4 yesterday and had a similar issue.
I managed to connect by just logging in to the hub and disabling 5 ghz temporarily.
Turned it back on once installed and all worked well..
