My 5GHz connection keeps going
I am fairly new to Virgin - 3 months - but this last week I've last my 5Ghz band 4 times this last week and had to reboot the router. Any ideas? I already have seperate SSID for 5 and 2.4 Ghz
  • 11.77K
  • 917
  • 1.51K
Re: My 5GHz connection keeps going
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
