  • 12
Message 1 of 18
Multiple Hub 3s, terrible WiFi in small home. 3rd Party Router recommendations please?
I've had multiple Hub 3s, however the Wifi has been atrocious, even when in the same room. It is temporarily fine when I reset the router, and split the 2.4/5ghz networks, however evntually, it becomes very slow, with zoom calls cutting out, and social media etc not loading properly. Speed via Ethernet is fine which leads me to believe it's a crappy router.
Myself, like most other people, are working from home, and I can't afford to have a bad connection, especially as I'm paying for 200mbps, therefore I'm now looking for router recommendations, something that works well with the Hub 3.0 in modem mode.
I'm not looking for a mesh system, as I honestly don't think it's worth it (I live in a normal 3 bedroom semi-detached home, not large at all). I'm hoping one good router will cover my home
Tags (2)
  • 3.53K
  • 568
  • 1.39K
Message 2 of 18
Re: Multiple Hub 3s, terrible WiFi in small home. 3rd Party Router recommendations please?
If you've had multiple routers and the problem persists, it is very unlikely to be faulty routers.  Don't spend a penny on a new router or mesh until we've got a clear take on what's happening.  As a start, suggest you post the hub's status for Donwstream, Upstream and Network log.
  • 12
Message 3 of 18
Thanks. Do you mind telling me how to post those details?
the reason I think it’s still the router is because it’s purely the WiFi that’s bad. Ethernet wise it’s amazing, but after a while, the WiFi just becomes patchy, however that being said, if I reset it, create 2 brand new networks, it’s fine for a couple days.
  • 15.68K
  • 1.64K
  • 2.67K
Message 4 of 18
As Andruser says - you have had multiple Hubs - so its not a Hub issue.
You say ethernet connections are "amazing" and it's its just wifi.
If that is the case, I would be taking a punt and ditching the Hub's "average" wifi and getting my own much better quality wireless equipment. I did that many years ago and have never had a wifi issue.
But would be worth looking at the stats - see protocol below...
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before] click on the “router status” icon/text at bottom-middle of first page up and then copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button a second time).
  • 3.53K
  • 568
  • 1.39K
Message 5 of 18
Do as John suggests to post the data, but if you paste it as "formatted text" it makes life sooo much easier for us.  Whatever you do don't post as images, often they're illegible due to poor resolution, they take time for the mods to approve them, and if they show IP or MAC addresses they won't get approved.
  • 12
Message 6 of 18
Thanks all, information is below (I've tried to format as best as I can).
STATUS
ItemStatusComments
Acquired Downstream Channel (Hz)411000000Locked
Ranged Upstream Channel (Hz)60300000Locked
Provisioning State
Online
DOWNSTREAM:
Channel, Frequency (Hz), Power (dBmV), SNR (dB), Modulation, Channel ID
14110000004.135256 qam31
2195000000134256 qam8
3203000000135256 qam9
4211000000135256 qam10
52190000000.735256 qam11
62270000000.235256 qam12
72350000000.235256 qam13
82430000000.535256 qam14
92510000000.935256 qam15
10259000000135256 qam16
112670000001.235256 qam17
122750000001.435256 qam18
132830000001.535256 qam19
142910000001.535256 qam20
152990000001.735256 qam21
16307000000235256 qam22
173150000002.735256 qam23
18323000000335256 qam24
193630000003.535256 qam25
203710000003.735256 qam26
21379000000435256 qam27
22387000000435256 qam28
233950000003.935256 qam29
24403000000435256 qam30
Channel, Locked Status, RxMER (dB), Pre RS Errors, Post RS Errors
1Locked35.513804275
2Locked34.989781778
3Locked3569823716
4Locked3547011757
5Locked35.522070700
6Locked3581717602
7Locked3566695487
8Locked3553176377
9Locked35.731096324
10Locked3562774316
11Locked35.537447297
12Locked35.532542248
13Locked35.534122240
14Locked3568150204
15Locked35125771279
16Locked35.540789329
17Locked35.518421237
18Locked35.519093430
19Locked35.510877294
20Locked35.513806267
21Locked35.525623287
22Locked35.76897231
23Locked35.58446240
24Locked35.712137167
  • 12
Message 7 of 18
UPSTREAM
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1603000004.675512064 qam9
2394000004.596512016 qam12
3462000004.575512032 qam11
4537000004.625512064 qam10
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
NETWORK LOG:
TimePriorityDescription
24/07/2020 16:00:10noticeLAN login Success; (removed MAC address)
24/07/2020 02:27:48criticalNo Ranging Response received - T3 time-out; (removed MAC address)
24/07/2020 01:04:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified; (removed MAC address)
24/07/2020 01:04:38ErrorDHCP REBIND WARNING - Field invalid in response;(removed MAC address) QOS=1.1;CM-VER=3.0;
  • 12
Message 8 of 18
STATUS:
Item
Status
Comments
411000000
Locked
60300000
Locked
Provisioning State
Online
DOWNSTREAM:
Downstream bonded channels:
ChannelFrequency (Hz)Power (dBmV)SNR (db)ModulationChannel ID
ChannelLocked StatusRxMER (db)Pre RS errorsPost RS errors
1Locked35.513804275
2Locked34.989781778
3Locked3569823716
4Locked3547011757
5Locked35.522070700
6Locked3581717602
7Locked3566695487
8Locked3553176377
9Locked35.731096324
10Locked3562774316
14Locked3568150204
15Locked35125771279
22Locked35.76897231
23Locked35.58446240
  • 12
Message 9 of 18
Logs posted above and here, apologies, I've tried to format as best as possible
FYI, I don't mind spending between £100 - £200 on a decent router as my livelihood now literally depends on having a good wifi connection throughout the day, but can this router be 'Mesh' ready for the future? I'm planning on possibly extending the house/loft to have a home-working space 1-2 years from now.
I'm not too keen on a massive mesh network with access points jotted around the house currently, but would love if the router I get now is Mesh ready for the future, as I can even run ethernet wires so there's optimal coverage.
DOWNSTREAM
ChannelFrequency (hz)Power (dBmV)SNR (db)ModulationChannel ID
1Locked35.513804275
2Locked34.989781778
3Locked3569823716
4Locked3547011757
5Locked35.522070700
6Locked3581717602
7Locked3566695487
8Locked3553176377
9Locked35.731096324
10Locked3562774316
14Locked3568150204
15Locked35125771279
22Locked35.76897231
23Locked35.58446240
  • 7.54K
  • 593
  • 1.28K
Legend
Message 10 of 18
Need downstream levels as well, but those upstream are bad, should all be 64 QAM. You probably need a technician’s visit to correct. Don’t even think of getting your own router until your circuit is fixed. Call customer services and report the issue or wait awhile for a VM staff member to get to your post.
