  • 27
Message 1 of 47
Multiple Extenders - same Hub
How do I pair two extenders to the same Hub at the same time.  How do I know which one is which if the Hub ID is copied?
VM extenders and SuperHub4
  • 14.73K
  • 620
  • 1.42K
Message 2 of 47
Re: Multiple Extenders - same Hub
You don't.
  • 24.55K
  • 1.41K
  • 3.12K
Message 3 of 47
Yes. But you’d be better off getting your own better extenders or a mesh system.
  • 27
Message 4 of 47
Please explain more fully.
Are you saying that it can be done? What do you mean by "better extenders" and what is a "Mesh" system?
  • 24.55K
  • 1.41K
  • 3.12K
Message 5 of 47
Yes it can be done.
What extenders do you have at the moment?
  • 27
Message 6 of 47
I have the ones that VM provided.
I had been using them with the Hub 3 and they showed up as VMP******.  I have since had the Hub 4 installed but the extenders don't show up separately.  I don't know if that is because Have cloned the network name (or at least think that I have)?. They must be working though as I can turn the Wi-Fi off and they work via ethernet?  I just don't know where I am with them as they are providing 75Mb of an incoming 1060Mb signal?
  • 24.55K
  • 1.41K
  • 3.12K
Message 7 of 47
75Mbps is about right.
A. They’re cheap plugs and
B. They’re powerline technology which relies on decent electrical wiring and ring mains etc.
Hence why I said some better extenders or a mesh system you purchase yourself would (always) be better.
  • 27
Message 8 of 47
Can you:
: Recommend decent extenders
:explain (or recommend) what a Mesh system is?
TIA
  • 24.55K
  • 1.41K
  • 3.12K
Message 9 of 47
Mesh system: https://www.amazon.co.uk/Best-Sellers-Computers-Accessories-Whole-Home-Mesh-Wi-Fi-Systems/zgbs/compu...
I would always go for a mesh system over an extender. But if you do go with an extender I would take this:
https://www.amazon.co.uk/dp/B0725Y1VZ7/ref=cm_sw_r_cp_api_i_Z6PLFb793WGT6
  • 27
Message 10 of 47
TVM
