tari
  • 6
Message 1 of 12
Move FTTP box inside
Hi, just went live with the Virgin 350 broadband. They installed a brown box outside of my home. Is it possible to move it inside, as it is very easy to open and cut the wire?
Tags (3)
apcyberax
  • 33.39K
  • 1.87K
  • 5.94K
Message 2 of 12
Re: Move FTTP box inside
no it has to remain on the outside
BenMcr
  • 21.38K
  • 2.32K
  • 4.28K
Message 3 of 12
No, all Virgin Media properties have a connection box on the outside in addition to any internal wiring.
tari
  • 6
Message 4 of 12
thanks for the quick reply.
End if i ask to redo the wire that comes from the underground "central box" to my omnibox so that it's long enough to go inside?
Would that do?
Not sure why it has to stay outside.
And the yellow cable that is inside the box? What is it?
(Pardon my ignorance, i'm new to coax and "glass" cables)
tari
  • 6
Message 5 of 12
Would that do?
apcyberax
  • 33.39K
  • 1.87K
  • 5.94K
Message 6 of 12
if you are worried about a metal box around it.
You can't modify the cable yourself.
the yellow tables sounds like fibre do you have FTTH
tari
  • 6
Message 7 of 12
it's the virgin 350 so i suppose it's fibre
apcyberax
  • 33.39K
  • 1.87K
  • 5.94K
Message 8 of 12
the 360 box is still coax. all FV services work on coax. it just depends if its converted to coax at your house or the green box
tari
  • 6
Message 9 of 12
There is some conversion going on
apcyberax
  • 33.39K
  • 1.87K
  • 5.94K
Message 10 of 12
yes thats fibre
