Hello all, first post so hope I've done this right.
I appear to have good wired broadband access but my Wifi has all but disappeared I am getting around 9mbps on devices next to the hub 3 but my Daughter and Son are now unable to connect via wifi and cannot attend their online lectures, things like Alexa don't work either although I have a VM supplied wifi booster in that room (cat 5 cable works fine using booster about 140 mbps).
I also have a constant orange light instead of white on my hub3 (see below)
I have unplugged my hub (3 times) and reset it (pin hole on back of plug also 3 times) and there has been no change other than maybe Wifi worse.
Can anyone suggest a course forward as the trust pilot reviews suggest contacting VM would be useless.
Many thanks
Mark
