on 24-06-2021 20:53
Hi all,
I recently purchased Mesh S4 Wifi extenders. When connected they do work fine. However as my son prefers the speed from a powerline adaptor that we currently connect to the router ( and other plug into his PC).
I tried to put the router into modem mode and the PC cannot connect to the Internet. Although, it network found. The Wifi does work.
Any ideas on how to fix this issue would be much appreciated.
on 24-06-2021 21:22
you need to connect the powerline adapter to the primary mesh node, not the hub.. in modem mode, teh hub only supports a single ethernet connected device so..
hub--->s4 primary--->powerline adapter
is how it should look.
on 25-06-2021 11:58
Thanks for reply and helping sort out my issue - much appreciated.
Pari.
