  • 17
Message 1 of 7
Modem Mode Hub 3 keeps dropping speed to 100mb from Gigabit 1000mb
I have my Hub 3 in Modem mode, when I connect to to my Route I get full speed of around 380mb, after 1 minute or so the line indication says it has dropped from 1000mb to 100mb and my speed drops to around 90mb.
If I unplug wait a few second and then plus back in I get full speed again for about a minute of so before it drops back down.
I sus pet its the Hub 3 thats dropping the speed, but why??
  • 11.32K
  • 1.15K
  • 1.81K
Message 2 of 7
Re: Modem Mode Hub 3 keeps dropping speed to 100mb from Gigabit 1000mb
Hve you tried a new Cat6 ethernet cable and changed ethernet ports on Hub3 and/or the router?
What make/model router is it?
Does have QoS activated that is limiting speeds ?
  • 17
Message 3 of 7
The cables are all Cat 6 and they have been changed. The router is an AirPort Extreme and I don't think it has QoS. I originally has a Asus RT-86U but sent this back to amazon thinking it was the problem, so until I get a new one my old AirPort Extreme is doing the server duties.
One thing I have changed is I have installed a Three Home Signal 2.4ghz booster for my poor 3G signal, it located close to my WAN Ethernet cable, could this be the problem and causing interference to the line.
  • 11.32K
  • 1.15K
  • 1.81K
Message 4 of 7
Just unplug/disable the Three booster temporarily, and see if the problem goes away.
  • 13.22K
  • 523
  • 1.21K
Message 5 of 7
Maybe you have a bad cable if its dropping from 1000mb to 100mb .
  • 17
Message 6 of 7
I unplugged the Three Home Booster and the problem returned after 5 minus back down to 100mb line speed, instead of gigabit.
When the Hub 3 is in Modem mode can it do any form of QoS.
  • 11.32K
  • 1.15K
  • 1.81K
Message 7 of 7
No - any QoS will be coming from your router - or the devices may be limiting it.
