  • 6
Message 1 of 11
Minimum WiFi on M500
Hi - I’ve been trying to contact virgin for around a month as struggling with minimum WiFi on M500! I’ve tried everything, factory reset, rebooting, connect app does not allow me to do a black spot check! I’ve tried messaging via virgin media app but receive error message saying unable to contact to virgin. I’ve just waited on hold to virgin for another hour for it to cut off. When I call the recorded message says I can see you’ve recently contacted us for help but I get none. Virgin media app error says oops there’s a problem! HELP PLEASE! (I’m not technical at all!) TIA
  • 24.97K
  • 1.44K
  • 3.18K
Message 2 of 11
Re: Minimum WiFi on M500
What do you mean minimum Wi-Fi?
There’s no guaranteed or minimum speed for Wi-Fi.
  • 6
Message 3 of 11
My laptop and phone say they are connected to WiFi but my pages won’t load, everything takes ages. In the app it says please connect to WiFi but my settings say I am connected to it?! My virgin apps say please connect - but I am? Thanks
  • 24.97K
  • 1.44K
  • 3.18K
Message 4 of 11
Try a 60 second pinhole reset on the hub
  • 6
Message 5 of 11
I have tried that twice and a month ago the automated virgin call did say they were sending a boost but no improvement
  • 24.97K
  • 1.44K
  • 3.18K
Message 6 of 11
What are your wired speeds like?
  • 6
Message 7 of 11
Just asked my son and he says it varies from 26kb/s to 400mb/s at no particular times
  • 24.97K
  • 1.44K
  • 3.18K
Message 8 of 11
How are those speed tests being carried out and from what device?
And is that when wired direct to the hub and not via a switch or powerline or extender plug?
  • 6
Message 9 of 11
Via his Xbox - wired. It comes up what speed it’s downloading when he’s gaming
  • 24.97K
  • 1.44K
  • 3.18K
Message 10 of 11
Testing via a console is never accurate.
You need to use a desktop or laptop with a gigabit Ethernet port and a CAT5E or better cable.
