Roboj0
  • 36
  • 11
Message 1 of 5
Might a pod help and if so can I order?
Our Hub 3 is in the upstairs back bedroom but the Firestick in the downstairs living room buffers. It is probably the device in the house that is the furthest away from the hub and would like to see if pod would help before shelling out on new kit.  (I do have O2/volt)
Thanks, Jo
  • 35.06K
  • 3.41K
  • 6.67K
Message 2 of 5
Re: Might a pod help and if so can I order?
Pods are free to volt customers - so makes sense to try them first - see this...
__________________
VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max
https://www.virginmedia.com/help/wifi-max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
Roboj0
  • 36
  • 11
Message 3 of 5
Thanks - I'll hang around here for a response/message as I sometimes lose the will on the phone🤣.
Tags (3)
  • 35.06K
  • 3.41K
  • 6.67K
Message 4 of 5
The website might offer alternative options - not sure.
Roboj0
  • 36
  • 11
Message 5 of 5
Sorted via WhatsApp - thanks
