@Mark0405 wrote:
Thanks again.
I'm a little unclear how many packs I should go for. Would two suffice do you think or is three more sensible?
You need to plan this out yourself as you need to consider the following;
1 - Every unit will need to be within wifi distance of the next.
2 - Every unit needs to be beside a power socket.
3 - The main unit needs to be near the VM Hub (in Modem mode) for ethernet cable attachment.
So, with this in mind, you can decide if 2 or 3 units will do the job. It may be you will need one on each floor for best performance. Remember walls and internal wooden doors can block wifi signals.
As previously mentioned, it may also be worthwhile to consider if you can cable any of the remote units back to the main one, as a cable "backhaul" will never be affected by wifi interference. Remember cable can be routed outside and up walls, it does not have to be internal.
