Mesh as an access point disconnects
jonbxx
I have a Hub 4 as the Cable Modem and am using a Mesh system to extend WiFi through the house. My preferred way of working is to use the Mesh system in access point mode and let the CM do the DHCP/router job. This is due to needing multiple ethernet connections and having a separate SSID for direct connection in case the Mesh system goes down.
As few months back, I started having problems with my TP-Link Mesh systems connection with the modem. which meant I had no internet access through the Mesh. Rebooting the primary unit connected by ethernet to the modem restored the connection. Working with TP-Link, they replaced the Mesh system under warranty but I still has the same issue. I suspected that the Mesh system which used a hybrid WiFi and Powerline backhaul might be the problem so I bought a new cheap Mesh system which worked well for a while but now I am getting dropouts again requiring a reboot of the Mesh system.
Am I doing something wrong here? After using three different Mesh systems, I will get loss of internet connection which suggests that it is the modem at fault here but is this a bad modem or bad setup on my part?
10 REPLIES 10
Robert_P
Hello jonbxx
Sorry to hear of the connection issues experienced, we appreciate the confusion and you taking the time to raise this via the forums.
We're limited to the advice we can offer where third party equipment is used and limited to what we can see connection wise when the hub is in modem mode. From looking though there does appear to be some power level issues with the hub that will require a tech.
I will send you a Private Message to get some more details from you.
Rob
The hub is in normal mode at present. I am using the mesh system in access point mode
jonbxx
Just as an update, we had and engineer round to check the signal levels and they were low. He refreshed all the connections but this needs further work at the cabinet to fix. I have had two dropouts since his visit
Lets see the connection data - do this..
________________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
jonbxx
Hi, here's the data;
1138750000-4.59999835.083549QAM2561
2146750000-5.00000035.083549QAM2562
3154750000-5.09999835.595078QAM2563
4162750000-5.09999835.595078QAM2564
5170750000-5.00000035.083549QAM2565
6178750000-5.00000035.595078QAM2566
7186750000-4.90000235.595078QAM2567
8194750000-5.09999835.595078QAM2568
9202750000-5.00000035.595078QAM2569
10210750000-4.90000235.595078QAM25610
11218750000-4.50000035.595078QAM25611
12226750000-4.50000035.779911QAM25612
13234750000-5.09999835.595078QAM25613
14242750000-5.79999934.483570QAM25614
15250750000-5.59999834.345688QAM25615
16258750000-5.20000134.925610QAM25616
17266750000-4.70000134.925610QAM25617
18274750000-4.20000135.083549QAM25618
19282750000-4.59999834.925610QAM25619
20290750000-4.90000234.925610QAM25620
21298750000-4.70000134.925610QAM25621
22306750000-4.50000034.483570QAM25622
23314750000-4.50000034.483570QAM25623
24322750000-4.90000234.345688QAM25624
25330750000-4.70000134.345688QAM25625
26338750000-4.09999834.483570QAM25626
27346750000-3.79999934.483570QAM25627
28354750000-4.00000034.345688QAM25628
29362750000-4.50000033.956509QAM25629
30370750000-4.40000233.834164QAM25630
31378750000-4.40000233.956509QAM25631
3.0 Downstream channels
1Locked35.08354900
2Locked35.08354900
3Locked35.59507800
4Locked35.59507800
5Locked35.08354900
6Locked35.59507800
7Locked35.59507800
8Locked35.59507800
9Locked35.59507800
10Locked35.59507800
11Locked35.59507800
12Locked35.77991100
13Locked35.59507800
14Locked34.48357000
15Locked34.34568800
16Locked34.92561000
17Locked34.92561000
18Locked35.08354900
19Locked34.92561000
20Locked34.92561000
21Locked34.92561000
22Locked34.48357000
23Locked34.48357000
24Locked34.34568800
25Locked34.34568800
26Locked34.48357000
27Locked34.48357000
28Locked34.34568800
29Locked33.95650900
30Locked33.83416400
31Locked33.95650900
and the upstream;
3.0 Upstream channels
14960000055.7705995120 KSym/sec64QAM1
22360000052.2705995120 KSym/sec64QAM9
33010000053.5205995120 KSym/sec16QAM4
43660000054.2705995120 KSym/sec32QAM3
54310000054.7705995120 KSym/sec64QAM2
jonbxx
And here's the log for Yesterday when I had two dropouts;
Wed May
31
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
6US profile assignment change. US Chan ID: 13; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
Wed May
31
6US profile assignment change. US Chan ID: 13; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
Wed May
31
6CM-STATUS message sent. Event Type Code: 23; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
5Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
6CM-STATUS message sent. Event Type Code: 21; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
Wed May
31
Wed May
31
Wed May
31
Wed May
31
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed May
31
6CM-STATUS message sent. Event Type Code: 16; Chan ID: 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mmmmm.. up power levels are a bit high and there is random dropping of the QAM's to 16/32 - thats not good - you are missing the T error table for upstream
Oops, sorry, here's the upstreat error table (not much to see though);
1US_TYPE_ATDMA0000
2US_TYPE_ATDMA0000
3US_TYPE_ATDMA0000
4US_TYPE_ATDMA0000
5US_TYPE_ATDMA0000
Hi @jonbxx,
Sorry you're still having issues following the technician visit.
How did the tech leave things with you?
I can see there is still a power level issue so will pop you a PM 📩 to assist further.
Ayisha_B
