PK20
  • 14
Mesh WiFi
I’ve bought a Netgear Orbi mesh system, would I be better putting my Virgin hub 3 in modem mode or leaving it as it is ??
thanks
tehwolf
  • 1.66K
  • 274
  • 408
Superfast
Re: Mesh WiFi
thanks
that's teh general recommendation, yes. The orbi routing features are likely to be a lot richer than the hubs.. you need to follow a specific sequence to get modem mode set up..
Log into the hub on http://192.168.0.1 and select the option to put the hub into modem mode
The hub will then reboot and come back up in modem mode - give it five minutes to settle down
Disconnect all ethernet cables from the hub
Power off the Hub and your router/mesh system
Connect your router/mesh system to the hub via ethernet cable and switch it on - leave it five minutes to settle down
Power on the hub and leave it five minutes to settle down
